Clip Truncated in project, but OK outside of FC.
Chris Walsh
on Nov 11, 2010 at 12:57:26 am
I have a two-camera, Standard Def, DV project that I've been working with over the last 9 months, consisting of songs from the SXSW festival that we edit and post to our blog.
Tonight, I started to edit a song, and noticed that the footage for both cameras ended about :30 secs before the song did (audio is mastered separately, then imported). Opening the clips outside of Final Cut, with Quicktime player showed the source footage to be longer and at the expected full duration (to the end of the song). When I imported them into a new project, the clips came through at their full correct duration.
Has anyone else had a similar problem, or is there a clip or metadata setting in Final Cut that I could have changed accidentally for these two clips?
Chris Walsh
http://www.musicfog.com
Silver Spring, MD
Final Cut & AVID MC5
Former Windows User and edit* lover
