Graphic has artifacts
Michael Prescott
on Nov 10, 2010 at 5:30:19 pm
I prepared a title card in Photoshop at 1024 x 576, text on transparent background. When it's composited in FC (on V2 above V1), white artifacts are appearing around the edge of the letters. When I re-sized the same graphic for the NTSC version (720 x 480), there are no artifacts. Any idea what might be causing the problem?
PAL version:
NTSC version:
Terry Ballard
Re: Graphic has artifacts
on Nov 10, 2010 at 5:43:28 pm
Michael,
I've had better success using .tiff files. Try that...
Terry B
MacPro two 2.26 Ghz Xeon
MacPro RAID card
AJA Kona3 video capture interface
AJA K3 breakout box
FCP & CS4
Dave LaRonde
on Nov 10, 2010 at 6:01:21 pm
Those white artifacts look like incomplete erasures. Is that possible?
Dave LaRonde
Sr. Promotion Producer
Michael Prescott
on Nov 10, 2010 at 6:33:37 pm
Terry: the above pictures were JPEG's only for posting here; its not what was used in the project. But I just discovered something interesting: the NTSC graphic was indeed saved as a TIFF, but the PAL was saved as a PNG. I had always thought the consensus in this Forum was to use PNG but I'll redo it as a TIFF to see if its better.
Dave: the graphic was created with a text only on a transparent background so, in Photoshop, nothing was erased. In fact, I used the exact same file for each version, only resizing for the proper aspect ratio.
Michael Gissing
on Nov 10, 2010 at 10:34:45 pm
What codec were the timelines? DV will make a mess of your graphics. Also PAL is 720 x 576 so you would be better making the correct aspect and not relying on FCP to do the anamorphic distort.
Michael Prescott
on Nov 12, 2010 at 3:08:33 am
The timeline codec was 8-bit uncompressed 4:2:2. I thought this would actually help the graphic look better. Also, the Sequence frame size was 720x576 even though the original graphic was created at 1024x576.
