iMac editing RED guide
Kazumi Hatori
on Nov 10, 2010 at 11:55:49 am
Hi I've been editing HD at my i7 iMac 27", with FCS 3 editing Prores.
So now I got opportunity to edit a 3 minutes RED project,
seems like there are different flows (RED RAW->proxy / RED RAW->Prores),
I would like to know if there is any guide to do that or advices~
I will work with FCP, with color for grading,
and finally output will be 1080p.
The thing I concerned most is that I can only work with a FW800 harddisc,
is that enough to edit proxy/Prores?
Ben Holmes
Re: iMac editing RED guide
on Nov 10, 2010 at 2:26:11 pm
There is a good whitepaper (with workflow guides) included with the RED FCS Installer. Given your hardware limitations, I'd recommend transcoding to ProRes to edit, then using Clipfinder to re-conform to REDCode so you can CC in Color - although the performance may be poor on the iMac.
A popular alternative is to use REDCine to do a one-light CC, then transcode to ProRes4444, and use these to edit and then in Color for CC. With a decent sized, RAIDed FW800 drive, you should be OK, just don't expect multi-stream playback. Also, playback may skip frames if the array is too full. Do some test yourself to see if this can work for you, as it avoids multiple transcodes.
Edit Out Ltd
FCP Editor/Trainer/System Consultant
EVS/VT Supervisor for live broadcast
RED camera transfer/post
Independent Director/Producer
http://www.blackmagic-design.com/casestudies/detail.asp?case=therydercup
Kazumi Hatori
on Nov 12, 2010 at 3:51:53 am
about the drive,
does it make it different between raid or normal through FW800?
and is Ethernet drive a solution for a iMac?
Mark Petereit
on Nov 10, 2010 at 4:02:00 pm
I'm far more worried that you're trying to grade color on an iMac.
Paul Jay
on Nov 10, 2010 at 5:01:18 pm
Indeed. Editing ProRes HD will run fine on an iMac with a good FW800 drive, but grading on a glossy high contrasy iMac monitor is not recommended.
Michael Gissing
on Nov 10, 2010 at 10:43:41 pm
RED make some good batch converters to make ProRes 1029 x 1080 files like REDRushes. Log & Transfer with the RED plugin can also do this job. Either way you should go to the RED site and study the various workflows and download their software or L&T plugin.
I don't recommend you try proxy workflows and grade the RED files with your setup. Convert to ProRes 422, 1920 x 1080 and work with that.
Kazumi Hatori
on Nov 11, 2010 at 10:15:04 am
Thanks all the useful comment!
I think i will go the Prores way.
I saw two software: RED Alert!, REDCINE-X,
is there any different to do the ingesting color correction?
