Sub-frame editing in timeline?
Jason Brown
on Nov 5, 2010 at 7:02:04 pm
Hey Guys,
If I take an audio clip into the viewer, I can hold down shift and move through the clip what I could call "subframe".
How do I do this in the timeline?
If I load the clip into the viewer from the timeline, I can do the same and then set a new in-point and it adjusts appropriately in the timeline, but I can't figure out how to move in the timeline with the same "subframe" navigation.
-Jason
Jerry Hofmann
Re: Sub-frame editing in timeline?
on Nov 5, 2010 at 7:36:42 pm
The software won't allow for this. Hey double click, adjust in viewer... it's not that much of a chore... It's the way it's designed to be done.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
DVD:http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX Cinema Displays
Jason Brown
on Nov 5, 2010 at 8:05:23 pm
Thanks for the clarification Jerry, no worries on having to double click...I was just wondering if there was a way...didn't figure there was since we have to work within the structure of "frame-by-frame" editing.
Jeremy Garchow
on Nov 5, 2010 at 8:52:50 pm
[Jason Brown] "didn't figure there was since we have to work within the structure of "frame-by-frame" editing."
That'd be pretty impossible since there's only 24 or 60 or however you shot, frames per second.
Audio, on the other hand, has 48,000 samples per second give or take. That's a lot more instances than 24 or 60. ;)
Jeremy
Jerry Hofmann
on Nov 5, 2010 at 8:53:11 pm
Hey no worries, and you are always welcome... there just isn't another way.
Jerry
Michael Gissing
on Nov 5, 2010 at 11:28:19 pm
Most editors I work with leave the sub frame stuff to us in audio post. DAWs have sample accurate editing. @ 24 frames there are 2,000 edit point in each frame on a DAW so mucking around in FCP is a waste of time. Also the OMF process from FCP will likely place the edit on a frame boundary anyway regardless of what you do.
