Are you just using file/send to/compressor? Wonder if trashing your plist for compressor might fix this and/or trashing prefs for FCP... It's not a bug nor is it a bad setting you could change don't think.
If you export a self contained movie and open that in Compressor instead, then I'll wager it will work OK, and still allow you to work in FCP during the compression... If you export a non self contained file, it should work OK too and be pretty fast if all of the renders are complete in your source sequence.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog:
http://blogs.creativecow.net/Jerry-Hofmann
DVD:http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX Cinema Displays
