FCP7 keyboard combinations fail
gabriele gismondi
on Nov 3, 2010 at 7:24:28 pm
hi,
just upgraded to FCP7 (total re-installation).
it looks great but the most of the default keybords short cut doesn't work..not even Z for Zoom or A for basic tool..just B for scissors seems to work..tried to change k.layout to US but nothing changes..choosing from the sidebar all commands works..any suggestions? thanks
Jerry Hofmann
Re: FCP7 keyboard combinations fail
on Nov 5, 2010 at 1:39:49 pm
Try trashing FCP prefs, if that fails, trash the plist file... post back with results.
Your problem isn't common. I've never read this happened in the past.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
DVD:http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX Cinema Displays
carlos fernandez
on Nov 22, 2010 at 5:55:13 pm
I am writing from Palma de Mallorca (Spain). I had exactly the same problem and I solved it by doing the following:
Go to FCP7 Tools - keyboard layout -Default Layout -U.S. Ignore the warning and press OK. Your problem will be solved.
Good luck!
Jerry Hofmann
on Nov 24, 2010 at 6:31:17 pm
Great answer!
Jerry
Current DVD:
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
gabriele gismondi
on Nov 24, 2010 at 6:35:55 pm
hi friends, thanks for tips.
I solved the problem just yesterday..
a friend suggested my this way: before launching FCP go to Mac Preferences/international; then move english as first language and italian (i'm from italy..) as second, then just do vice-versa, move italian as first language and english as second. close Pref and launch FCP..here it goes!
