media managment
Ryan Grassby
media managment
on Oct 27, 2010 at 10:12:31 pm
Before editing a music video I originally had footage split between to external hard drives and did not maintain organization of my media as I edited. At one point I renamed the all files which obviously was a mistake. Anyway, I've copied everything over to one hard drive but even after that for some reason almost all the media is offline unless both hard drives are connected. I've copied absolutely everything that could have anything to do with the video from one hard drive to the other but they both still need to be plugged in. I also tried using media manager with FCP to reorganize the referenced files into one location but either that didn't work or I didn't do it right. Does anyone have any ideas as to a potential solution to this problem? Thanks.
Dave LaRonde
Re: media managment
on Oct 27, 2010 at 10:23:59 pm
You need to look at your capture scratch settings. Is that old drive still listed?
Dave LaRonde
Sr. Promotion Producer
© 2018 All Rights Reserved
