Wierd strobiness (starts ramndomely) on Multiclip playback mostly
Ariel Brener
on Oct 26, 2010 at 11:16:14 am
Something very weird happens:
I Edit HD multi-cam footage.
Every thing works great and smoothly.
but after a while - and I cant point specifically when or after what action.
when I hit "play" I get a strobe picture.
also when I turn off the multi clip playback
and even if I play back regular non-multiclip footage. with no effects (render bars are grey).
when I relunch FCP problem continues.
only after restart it comes back to normal playback.
I have two intel mac pro on the network.
maybe it has something to do with that?
maybe cluster render settings are set wrong?
I get the same problem on the other machine as well (but less often)
Did any of you good people expeariance it?
Any ideas?
© 2018 All Rights Reserved
