FCP 7 timecode to FSI Monitor
Lee Warner
on Oct 23, 2010 at 5:58:20 pm
I checked with Matrox to see if the MX02 would pass TC embedded in the SDI stream to a 1760 monitor. The answer was yes. What I don't know is if FCP actually passes that TC signal along to the MX02. It's not a biggie but I would like to see my TC on the FSI monitor. None of the TC settings on the monitor work (LTC, VITC1 or VITC2).
Any ideas?
Lee
SAMDOG Digital Post
Calgary, Alberta
Mac Pro 2.66 12-core 16gb ram • FSI LW1760 Monitor • Matrox MX02 • Caldigit HD One 8tb Raid • Euphonix MC Transport • Final Cut Studio 3 • Adobe Production Premium Bundle
Rafael Amador
Re: FCP 7 timecode to FSI Monitor
on Oct 23, 2010 at 6:32:27 pm
Hi lee,
I think that's not possible because a limitation of FC.
If I'm not wrong, the only way to get the TC out of FC is through RS-422.
rafael
http://www.nagavideo.com
Andrew Kimery
on Oct 23, 2010 at 7:51:24 pm
I think Rafael is correct. I don't believe FCP can embed TC in an SDI stream.
-Andrew
3.2GHz 8-core, FCP 6.0.4, 10.5.5
Blackmagic Multibridge Eclipse (6.8.1)
Jason Brown
on Oct 23, 2010 at 8:00:51 pm
I had the same situation a while ago...and I believe rafeal is right. It's a limitaion of fcp. I believe I've tested it since with Sdi from my camera and gotten it to work.
Joe Paolo
on Oct 24, 2010 at 2:09:17 am
I have the MXO2 and 1760 also. While the TC display works fine with decks I have never gotten to work with FCP. If you use the cross hatch you can see the vitc on tape playback but FCP (or quicktime) strips all that stuff off.
joe
editmojo.com
