Media Manager use multi-threading?
Uli Kunkel
on Oct 22, 2010 at 4:24:16 am
Does anyone know if the Media Manager in FCP supports multithreaded processing on the "Recompress" setting? I'm pretty sure it uses the same engine Compressor uses, but I'm not sure if it accesses multiple cores like Compressor.
Thanks for your help.
Uli
Michael Gissing
Re: Media Manager use multi-threading?
on Oct 22, 2010 at 5:13:50 am
In Compressor you have to select the Qmaster cluster to use multi core. I see no such option in Media Manager so I presume it doesn't use Qmaster, therefore not multi core.
