Log and Transfer crashes FCP
Nate McNeil
on Oct 21, 2010 at 8:45:29 pm
Recently I've encountered something strange in Log and Transfer. Whenever I try to mount a folder with File Based Media in it, Final Cut crashes and returns an "Unexpected error".
I've tried this on both XDCAM and P2 footage, from a variety of drives and it happens no matter what I try to load. I've also tried trashing preferences and all the other usual suspects to no luck.
I'm hoping to avoid a full uninstall and re-install if possible. If anyone has any insight it would be greatly appreciated.
Nate
Jerry Hofmann
Re: Log and Transfer crashes FCP
on Oct 22, 2010 at 1:11:16 pm
Is the folder on a hard drive or on the card that recorded it? I'd be sure to copy from the card to a hard drive for import.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
DVD:http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX Cinema Displays
Nate McNeil
on Oct 22, 2010 at 3:53:33 pm
I've tried mounting data from an external SATA drive, from the tower itself, as well as RAID server, and they all encounter the same error.
