will Multicam editing using a XH-A1 and and F300 be possible
Jan Bliddal
on Oct 20, 2010 at 9:47:08 am
If the XH-A1 is set to 25F and the F300 uses the 1440x1080 25P setting and transcoding both to ProRes on Ingest before adding them to the Multicam time line?
Or will you suggest getting a XH-A1s to best match my current XH-A1 and adding FS-CF Pro Portable Compact Flash DTE Recorder to them if I want more than 1 our of record time filming presentations that goes beyond the 1 hour HDV tape maximum?
Let the machine work for you. Not you for the machine
Mark Petereit
Re: will Multicam editing using a XH-A1 and and F300 be possible
on Oct 20, 2010 at 12:23:34 pm
All the clips must use the same codec, image dimensions, and frame rate.
Jan Bliddal
on Oct 20, 2010 at 3:29:51 pm
Hi Mark I am aware of that part I am however not sure about 1440x1080F 25F beeing equal to 1440x1080 25P in the eyes of ProRes. I really would like the F300 do to its 50mbit 4.2.2 codec, but I would like to be able use it with my existing AH-XH1 camcorder in a multicame setup. And I am wondering if Canons HDV 1440x1080 25F and canons 1440x1080 25P format will match when transcoded through ProRez. I mean framesize is the same. framerate is the same I am just woundering if the F for Full is to different from the P as in Progressive
