VU meter UI for the 3.5mm output jack of Mac?
Brad Bussé
on Oct 20, 2010 at 12:36:10 am
Aside from using external hardware, is there a UI element of Mac OS or a freeware app that will show me a VU meter for the master mix being exported out of the 3.5mm headphone jack on a Mac?
Jeremy Garchow
Re: VU meter UI for the 3.5mm output jack of Mac?
on Oct 20, 2010 at 12:54:34 am
It's silly to put your thermosat outside to the control the temperature in your house
You can't meaure the output of something unless it's on the output side. You could use the Fcp meters as a guide, but unless you are measuring the output of the jack, you will neevr know what's coming out of it.
jeremy
