Frame placement in timeline
Ian Clark
on Oct 19, 2010 at 9:54:04 pm
Working on a stop animation project and want to learn how to automatically adjust multiple images' relative placement on the timeline, in relation to one another
For instance, say there's 1000 still images in the timeline and every third frame is deleted, leaving 2 frames- space- 2 frames- space, etc.
Is there a way to select all of these clips and make them snap together automatically so that I wouldn't have to manually drag each cluster of two frames to the cluster of adjacent frames and so on until I'm able to scrub through all of my images without black/breaks between frame sets?
Thanks, probably a pretty basic question, I'm just not animation guy.
IAN CLARK | http://www.incproductions.org
Rafael Amador
Re: Frame placement in timeline
on Oct 19, 2010 at 10:38:11 pm
No way Ian.
lets don't forget that FC is a video editing application.
rafael
http://www.nagavideo.com
Ian Clark
on Oct 19, 2010 at 11:19:33 pm
Hmmm... I'll keep searching for an answer. Anybody else?
Seems logical that this function would exist as you can do things like adjust the duration of still images in the sequence.
Chris Tompkins
on Oct 19, 2010 at 11:29:32 pm
There is a preference for the length of still imported.
Remove "all gaps" in sequence - that could be handy...
Chris Tompkins
Video Atlanta
Francois Jean
on Oct 19, 2010 at 11:55:21 pm
I don't know how you are actually deleting these frames...
You can "Ripple delete" (shift delete) these frame.
This can be time consuming but if you map it to a specific key for a shortcut...
hope this can help
ZAP
Jeremy Garchow
on Oct 20, 2010 at 12:27:32 am
http://forums.creativecow.net/readpost/8/1074689
Ian Clark
on Oct 20, 2010 at 5:12:50 am
Thanks Jeremy-
Rafael Amador
on Oct 20, 2010 at 4:02:31 pm
That's a good one.
rafael
