Unable to perform edit to tape on Digibeta using SDI
Jack Johnson
on Oct 19, 2010 at 6:44:10 pm
FCP 7
AJA Kona LHe
Digibeta DVW-A500
SDI In and Out
I have control of the deck and can log and capture fine. I need to black and code a tape and every time I press the button in the Edit to Tape window a get a dialogue box that says "Unable to perform Black and Code. The Tape appears to be write protected or the deck may be in Local mode."
Is there a setting I'm missing? Please help.
Shane Ross
Re: Unable to perform edit to tape on Digibeta using SDI
on Oct 19, 2010 at 6:53:16 pm
Is the deck in LOCAL mode? Or is it switched to REMOTE? You don't mention that. Nor if the tape's WRITE PROTECT tab is set for record.
Shane
Jack Johnson
on Oct 20, 2010 at 6:22:48 am
Today I learned that Digibetas do not record to BetaSP.
