Panasonic HDC-HS700
Daniel Mason
Panasonic HDC-HS700
on Oct 19, 2010 at 3:02:04 pm
Is anyone using this camera and editing in fcp 6 or express 4.0?
Panasonic HDC-HS700
Its format is MPEG-4 AVC/H.264 (AVCHD Standard compliant)
Just need to see if it actually is compatible before a buy a few of them for college use.
Danny.
Jerry Hofmann
Re: Panasonic HDC-HS700
on Oct 19, 2010 at 6:08:03 pm
It's compatible. FCP will use the log and transfer window to import the files as ProRes files.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
DVD:http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX Cinema Displays
Daniel Mason
on Oct 19, 2010 at 6:59:33 pm
Thanks for a quick response Jerry!
Danny.
Paul Dickin
on Oct 19, 2010 at 9:56:15 pm
Hi
Its not straightforwardly compatible if the 1080p60 28mbps MPEG-4 mode is used - for that you need something like Clipwrap, not FCP's L&T. Stick to 17mbps 60i AVCHD mode for compatibility.
