plugin that detects powerpoint slide change?
Michael Greenwald
on Oct 14, 2010 at 11:14:19 pm
Hello,
I work on a lot of projects with two sources, one being video of the presenter and the other being the presenter's powerpoint presentation, which is captured straight to HD as a video.
Does a plugin exist that can detect slide changes? From a programming standpoint, this wouldn't seem too hard to create because most slides look considerably different from one to the next. It would be incredibly helpful to drop a plugin on a video, and have it automatically sliced into pieces, where each piece is one slide, without having to go through manually and cut it up myself.
Michael
Jeremy Garchow
Re: plugin that detects powerpoint slide change?
on Oct 15, 2010 at 1:45:44 am
Perhaps scene detection software might work? I have no idea.
See here:
http://scene-detector.com/
Hope it helps.
Jeremy
Bouke Vahl
on Oct 15, 2010 at 2:21:43 pm
This should do the trick
(and i'm the one giving support...)
http://www.videotoolshed.com/product/13/recut
there is a free demo that tells you if it will work for you!
hth,
Bouke
smart tools for video pros
Jeremy Garchow
on Oct 15, 2010 at 5:26:37 pm
Sweet, Bouke. I didn't know you had this tool.
Michael Greenwald
on Oct 15, 2010 at 7:10:34 pm
sweet, thanks for the recommendations
