Audio Levels FCP to QT
Michael Harrington
on Oct 14, 2010 at 3:47:38 pm
Wrapping up long-term huge project, 80-hr HDV footage digitized in ProRes422 for 2-hr DVD. I'm exporting individual sequences to deliver for DVD Authoring from FCP to Quicktime (current settings). The quick-times occasionally have incorrect audio mix, more specifically keyframes to smoothly change audio level in FCP sequence are now much different in the quicktime, some levels actually pop on/off instead of faithfully reproduce as in FCP sequence. I've double checked the sequences and sound good. Not a consistent problem and happens occasionally.
Any thoughts on what's going on and what can I do to fix problem.
Michael Harrington
Mac Pro, Dual Quad-Core Intel Xeon 2.66 GHz, 12 GB, FCP7, Snow Leopard, ATI Radeon HD 4870, 30-inch Cine Display, 4 - 1TB internal, 1.25TB Esata, Numerous FW 800 external drives, MX02Max, FSI 17" Broadcast Monitor, Mackie 1402 & Event 20/20 monitors.
Dave LaRonde
Re: Audio Levels FCP to QT
on Oct 14, 2010 at 5:59:58 pm
Select All, then Sequence>Render Only>Mixdown.
I've read this simple trick can even help out certain video problems. Go figure.
Dave LaRonde
Sr. Promotion Producer
Michael Harrington
on Oct 15, 2010 at 3:50:36 am
I'll give that a try, of course I render before I make quick-times although I have not done the mix down audio in quit a long time.
Thanks for the tip.
Michael Harrington
