log & capture
Sarah Lewis
log & capture
on Oct 13, 2010 at 12:33:51 pm
Hi
I am 'log and capturing' 30 hours of footage onto FCP. FCP is creating a new file everytime the camera was turned off and on when filming - often this is up to 50 different shots per tape and I would much prefer to have only a couple of large files per tape. In the prefs I have deselected 'report dropped frames during play back and 'abort capture on dropped frames' and selected 'warn after capture'. Does anyone have any idea how I can change the prefs or what to do to capture all the footage in a large file?? Any help would be much appreciated.
many thanks
Sarah
Trevor Ward
Re: log & capture
on Oct 13, 2010 at 1:46:45 pm
Two questions before you can get an answer:
1. Are you using Firewire to capture (from either a camera or a deck)?
2. Does your tape have time code breaks?
-trevor ward
Red Eye Film Co.
http://www.redeyefilmco.com
orlando, fl
Sarah Lewis
Re: log & capture
on Oct 13, 2010 at 1:56:44 pm
Yes, I am using firewire from a Sony Z1 camera and NO I don't have any timecode breaks in tapes - it just seems to log each separate shot as a new file.
Sarah
Trevor Ward
Re: log & capture
on Oct 13, 2010 at 2:20:18 pm
Hmmm. I don't know then. I know iMovie does that sort of thing, unless you uncheck an option box. I didn't think FCP did that.
Have you tried logging your clips first, then doing a batch capture? Or are you using Capture Now?
-trevor ward
Red Eye Film Co.
orlando, fl
Jeremy Garchow
Re: log & capture
on Oct 13, 2010 at 2:14:51 pm
What format are you capturing?
Michael Gissing
Re: log & capture
on Oct 13, 2010 at 9:13:18 pm
In Log and Capture with HDV, there is a little check box in one of the tabs to enable a new clip on camera stop starts. Uncheck this if you want to capture long clips
Sarah Lewis
Re: log & capture
on Oct 14, 2010 at 6:24:26 am
Thanks so much - I think that may have solved it.
