Photoshop files into HDV timeline
Shannon Bedford
on Oct 13, 2010 at 4:36:23 am
What settings should I use to make the perfect photoshop file for importing into a HDV project?
I'm having issues with keeping transparency & correct aspect ratio.
cheers,
S Bedford, Western Australia
Bret Williams
Re: Photoshop files into HDV timeline
on Oct 13, 2010 at 6:33:35 am
In photoshop simply create a new document and select the flavor of HDV you're using. Drag the completed photoshop file into a bin and it will come in as a layered sequence. All your transparency settings should be retained. Or, alternatively save a copy as a png file which will also retain all your transparency.
Shannon Bedford
on Oct 13, 2010 at 6:55:48 am
I've selected preset 1080p (I'm using 1080i but it's not an option). But the option to give it a transparent background is greyed out.
Bret Williams
on Oct 13, 2010 at 1:45:39 pm
i or p have no meaning here. Its a still. It is progressive by nature.
Not sure what ps you have. Here's CS4 settings pic. If you cant get a transparent option, just delete the bottom layer in ps.
Shannon Bedford
on Oct 14, 2010 at 1:23:56 am
Thanks Pirate Bret, I didn't realise you could just delete the background once it was set. I'm pretty sure the old versions didn't let you do that.
Funny thing is, when I restarted photoshop today and tried again, "transparent" is no longer greyed out. I have no idea what has changed but everything is now as it should be.
Cheers
