Consolidating Footage in FCP
Alan Thompson
on Oct 12, 2010 at 3:49:41 pm
I am working on a project in FCP 7 where I have two different working resolutions, 720x480 and 1080x760. I was wondering if, when the project is consolidated, the two sizes would get mixed up and Final Cut would pull the dimensions from the lower res. footage? Thanks to all.
Jerry Hofmann
Re: Consolidating Footage in FCP
on Oct 12, 2010 at 4:09:16 pm
I'm not sure I understand the question. "Consolidating" might need a bit of explanation. If you mean just moving and archiving source media used, then no, FCP will not change dimensions of the original media.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
DVD:http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX Cinema Displays
