Share... Current Settings
Dustin Parsons
on Oct 12, 2010 at 12:33:04 am
Is there a way to export a Sequence from FCP using the sequence settings as the codec without tying up FCP or having to create the specs in Compressor?
Thanks for your help!
Shane Ross
Re: Share... Current Settings
on Oct 12, 2010 at 12:39:44 am
No. Render...export via FILE>EXPORT>QUICKTIME MOVIE...self contained, using sequence settings.
What other application will be able to export a sequence FROM WITHIN FCP? Only FCP has that sequence, so you need to export FROM FCP...
Shane
Dustin Parsons
on Oct 12, 2010 at 1:10:50 am
Thanks for the speedy reply! Sorry, I guess it was pretty stupid to have specified "within FCP".
Basically, the reason I ask is because I know that with FCP 7 you have the option of exporting using File > Share... which sends your timeline to Compressor (letting you continue to work in FCP), however, as far as I know there is no option for using Share... without going through the trouble of creating a Compressor setting to have the same specs as your FCP Sequence.
Please correct me if I'm wrong. Thanks again.
Mac Pro | Leopard 10.5.7
2.66GHz Dual-Core Intel Xeon | 4GB Ram
Final Cut Pro Studio 2 | Avid Media Composer
Shane Ross
on Oct 12, 2010 at 1:25:41 am
Well, I dont' use Share. I like having a file that I export and then can do what I want with it. Always have it to do whatever...so I don't have to go BACK to that project and export again. Exporting a self contained file takes very little time, especially when fully rendered.
Shane
