24p to 25p conversion
Ned Weisman
on Oct 11, 2010 at 8:08:17 pm
Does anyone have a Compressor setting to convert 1920x1080 pro res 24P to 25P??
Shane Ross
Re: 24p to 25p conversion
on Oct 11, 2010 at 8:37:09 pm
Do you need to keep the same duration? If you just use Cinema Tools to CONFORM frame for frame, you can make 23.98 to 25fps easily. Small speed shift (1%) and pitch shift in audio...but easy. Do this with stock footage all the time.
Shane
