FCP7 Clips Unrendered
gerald collison
on Oct 8, 2010 at 10:15:20 pm
I've got a clip that I captured to FCP 7. I don't think I had 48kHz "Anamorphic" just NTSC DV 48kHz selected as the capture settings, but I dont think that would make a differnce. Please tell me if I'm wrong. But the clip settings match the timeline,
720x480, DV/DVCPRO-NT, Data Rate only shows up on clip (3.6MB/sec), NTSC - CCIR 601, and Both Anamorphic's are checked for sequence and clip. Everything matches up except for Audio format, sequence being 32-bit Floating Point and Clip being 16-Bit interger.
Everytime I drag the clip to the timeline, however, it is unrendered? What gives? I can't figure out why the clip is unrendered. Any help would be greatly appreciated!
Jeremy Garchow
Re: FCP7 Clips Unrendered
on Oct 8, 2010 at 10:32:37 pm
Is there a filter?
Motion tab values not what they should be?
If you load a clip from the browser and make adjustments, that sticks with the master clip. If you put the clip on a timeline, it won't.
