judder on timeline only
dave young
on Oct 7, 2010 at 2:03:21 pm
I'm having a nightmare.
Clips are 25P PAL and they play fine in the viewer (locked off camera, boat goes across screen right to left). However, in the timeline (set to 25 fps PAL) the boat judders approx. once every second?
Help please. I need to deliver this tonight.
thanks
Dave
Jerry Hofmann
Re: judder on timeline only
on Oct 7, 2010 at 3:09:56 pm
If you don't need to deliver tape, you might find it still works OK in a QT movie or web stream if the problem is that it's just dropping frames. Is the message to warn you showing up or have you turned off the warning? Just sounds to me like dropping frames.
That said, what codec is the timeline set to be and what codec is this footage that stutters? Do they match? If not, you might try transcoding the source to the same codec and frame rate etc that the sequence is set to. DV? or?
Next question is what are you using as the scratch disk for the source footage? Shouldn't be your startup disk.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
DVD:http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX Cinema Displays
