ProRes codec to convert H.264 to ProRes
elka andrello
on Oct 6, 2010 at 8:58:15 am
I made a video using the canon 7D, imported files to Fnal Cut 6, tranformed the files in ProRes422. My question is: How can I transform my edited sequence back in full HD resolution H264?
I tried to export using Quicktime conversion / MPG4 / 1280x720 / data rate 5000 / frame rate current / key frame automatic .
Is it correct?
Than you!!!
Rafael Amador
Re: ProRes codec to convert H.264 to ProRes
on Oct 6, 2010 at 3:24:27 pm
Hi Elka,
Instead of MP4, export a QT movie with H264 and the same parameters.
Rafael
http://www.nagavideo.com
elka andrello
on Oct 7, 2010 at 6:22:25 am
Thank you for answering.
I tried to export to quicktime and the same thing happened.
