HD 1080p25 capture problem with AJA IoHD
Elmir Gasanov
on Oct 6, 2010 at 6:43:12 am
Hello.
I have a problem with capturing video HD 1080p25 from sony HDW1800 camcorder with Aja Io HD. The cassette recorded in 1080p25 standard. But both Aja Vtr Exchange and FCP capture see it only in 1080i50. I change vtr setting manually to 24 psf from System frequency menu and it is ok. But in this case i get 24frame video. but we shouted in 25p mode, and i need 25 frame video for editing. I have very little time for this. Please anybody help me with this problem. Thank you in advance.
Rafael Amador
Re: HD 1080p25 capture problem with AJA IoHD
on Oct 6, 2010 at 3:30:43 pm
[Elmir Gasanov] "I have a problem with capturing video HD 1080p25 from sony HDW1800 camcorder with Aja Io HD. The cassette recorded in 1080p25 standard. But both Aja Vtr Exchange and FCP capture see it only in 1080i"
Hi Elmir,
That is correct.
1080p25 is not standard for SDI.
1080 p25 is streamed as interlaced (psf).
You need to capture as 1080i50, then check it as NONE (progressive) in FC.
Edit
http://www.nagavideo.com
Elmir Gasanov
on Oct 8, 2010 at 8:45:01 am
Hi Rafel.
Thank you for your respond. Can you say if I can capture this video with Aja Kona 3 directly using 1080p25 in Aja Control Panel's Format Tab. Thank you
Rafael Amador
on Oct 8, 2010 at 2:54:06 pm
I don't think you need to change nothing in the Control Panel.
Use the AJA 1080i25 capture preset.
Rafael
Elmir Gasanov
on Oct 11, 2010 at 6:46:08 am
Thank you vey much
Rafael Amador
on Oct 11, 2010 at 10:37:45 am
Don't forget to check the clips as NONE in the Browser.
Rafael
