Changing the Speed Of a Clip does not Change its Duration Why?
Vaishakh Babu
on Oct 6, 2010 at 5:40:30 am
Hi Folks
Lately i have been having some weird stuffs happening in final cut...
thing is i select a clip and change its speed to 50% (modify -> change speed cmd+h) but the duration still remains the same, shouldn't it double
why is this happening
Jerry Hofmann
Re: Changing the Speed Of a Clip does not Change its Duration Why?
on Oct 7, 2010 at 12:43:00 pm
I'm sure you mean when you type cmd+j to change the speed.
In the window that opens, there is an option to ripple the sequence. If it's on, and you change the speed to say 50%, the length of the new clip will be twice as long as it was before. If it's off, you'll see the behavior you're reporting. So it's a setting, and actually a feature, because you can have the behavior be either way.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
DVD:http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX Cinema Displays
Vaishakh Babu
on Oct 9, 2010 at 6:11:40 am
thanks,
it worked
Dayna Casey
on Oct 23, 2010 at 11:02:34 pm
I'm having this same problem, but the ripple sequence is unclickable and
also the duration part. Does anyone know why?
I'm working in a sequence that has two different kinds of film - one NTSC
and one HD and the sequence settings are set to the HD. Does this make
a difference?
