Compressor Frame Controls settings question (and panic!)
Harry Powell
on Oct 4, 2010 at 10:51:02 pm
Sorry to cross-post this but I would really appreciate your help as I'm in a bit of a deadline panic!
I'm using Compressor 3.0.5, on an 8-core 'early 2008' Mac Pro with 14GB RAM.
Compressor is estimating over 30 hours to encode an 11 minute 1080i ProRes (self-contained from FCP) to 720p H.264. And ETA keeps increasing as time goes on! (it started as ETA of 8 hours)
I know I probably shouldn't put all the settings at their highest level in Frame Controls, but I did notice perfect quality on a short test, particularly on end credits which looked immaculate at 2000kbits/s (but didn't with the default Frame Control settings).
Normally, through trial-and-error, I would find out which of those settings is perhaps not necessary to get equally good results ... but I've found myself very short of time at this late stage (I'm not perfect).
Can any of these setting be altered without losing noticeable picture quality, and speed up the ETA by a significant amount?
i.e.
resize filter: Best
Output filds: Progressive
Deinterlace: Best
Adaptive details ticked.
Anti-alias: (slider on default, i.e to left)
Details level: (slider on default, i.e to left)
Rate conversion: Fast (Nearest frame)
Set Duration to: (default, i.e. greyed out)
'so source frames play at 25 fps' selected
HELP! (it's been a long day and tomorrow is delivery day!)
Andy George
Re: Compressor Frame Controls settings question (and panic!)
on Oct 5, 2010 at 12:00:46 am
Going From better to Best on your de-interlace is adding a significant amount of time to your render, and probably not adding an equal amount of value. Id turn that one down a notch.
-Andy George
Senior Editor
http://www.chiselindustries.com
Rafael Amador
on Oct 5, 2010 at 1:15:31 am
I agree with Andy, mostly if you are donwsizing at the same time.
rafael
http://www.nagavideo.com
Harry Powell
on Oct 5, 2010 at 5:57:32 am
OK I've switched from best to better on deinterlacing, and I'm testing this on just a 2 seconds sample, i.e. a self-contained export from Final Cut.
Compressor has been encoding this for 50 minutes, and is predicting completion in over 10 hours! And steadily increasing all the time.
QMaster is running and iStats shows all 8 cores being fully utilised.
Surely this can't be right? Seems to have got worse?
Rafael Amador
on Oct 5, 2010 at 6:29:23 am
Have a look to the Activity monitor and see if Compressor is really working.
rafael
Harry Powell
on Oct 5, 2010 at 6:48:02 am
Thanks Rafael for your suggestion.
Can you please tell me what exactly what I should look at in Activity Monitor?
There are various Compresssor related things listed and not sure which is most relevant and whether I should be looking at CPU or threads or ...?
Harry Powell
on Oct 5, 2010 at 6:30:50 am
UPDATE
I've just checked my original test done with the best settings listed in my first post.
It was a 2 minute sample and it took Compressor under 4 hours to complete.
And just to update you on my latest 2 second clip test (with deinterlace downgraded to better from best) .. it is now predicting 16 hours for completion.
Rafael Amador
on Oct 5, 2010 at 8:31:26 am
Try this:
http://www.digitalrebellion.com/compressor_repair.htm
rafael
Harry Powell
on Oct 5, 2010 at 9:34:33 am
Thanks Rafael for the repair programme. I'll use it next time I have a problem.
In the end I opened Batch Processor and I could see that it was still trying to encode the 11 minute edit, even though I had paused and deleted it from Compressor.
I then decided to stick with 'better' settings rather than 'best' in Frame Controls panel, and the encode finished within an hour.
I think, based on my initial 2 minute clip test, the 'best' settings would have taken about 24 hours so don't have time for that.
Now I have a different problem! (which perhaps I'll start a new thread with?), i.e. I have intermittent thin grey dashes at the bottom edge of the movie. Very distracting!
Any ideas?
Rafael Amador
on Oct 5, 2010 at 10:46:16 am
[Harry Powell] "In the end I opened Batch Processor and I could see that it was still trying to encode the 11 minute edit, even though I had paused and deleted it from Compressor. "
You may be suffering a bug that I thought was fully fixed.
On starting, Compressor try to finish jobs that has been canceled or haven't finished for any reason..
The fix: Clean the "History Window" before sending any job.
Try that.
rafael
Harry Powell
on Oct 6, 2010 at 7:06:20 am
Thanks again for the extra tip Rafael. I'll make sure to do that.
Dave LaRonde
on Oct 5, 2010 at 3:45:12 pm
I looked through this thread and I didn't see a single mention of the type of footage in your FCP edit timeline. If it's long-gop / interframe-compressed / temporally-compressed footage -- take your pick of what to call it -- it could very well be the cause of your long compression times.
The three most common culprits are XDCam, H.264 and mpeg footage. If you used any of these, you now know why people always say it's best to convert these types of footage to ProRes first.
It also means that since you're at the tail-end of your project, with absolutely no time to go back and fix the footage, you're kind of stuck between a rock and a hard place on that ridiculously-long export time.
Dave LaRonde
Sr. Promotion Producer
Harry Powell
on Oct 6, 2010 at 7:19:27 am
Hi Dave
Apologies for any confusion caused, but how does this from my initial post, not make it clear the type of footage in my FCP edit timeline?
"Compressor is estimating over 30 hours to encode an 11 minute 1080i ProRes (self-contained from FCP) to 720p H.264"
i.e. ProRes ?
Rafael Amador
on Oct 6, 2010 at 1:50:39 pm
You are not sending from FC, don't you?
rafael
Harry Powell
on Oct 6, 2010 at 4:40:39 pm
Rafael, I'm not sure if I understand your question correctly, but what I meant was, I export the ProRes in the Timeline as a self-contained QT movie, at current settings. I then put this self-contained QT movie in Compressor.
Are you suggesting I should be 'sending' to Compressor? I see that option for sending to Soundtrack Pro and Motion, but I can't see this for Compressor.
Rafael Amador
on Oct 7, 2010 at 1:20:16 am
[Harry Powell] "Are you suggesting I should be 'sending' to Compressor? I see that option for sending to Soundtrack Pro and Motion, but I can't see this for Compressor."
Not at all.
I just wanted to make sure that you were working with Self-contained movies.
Sending from FC, would take much more time.
rafael
