Syncing issues...
Strider Cangiano
Syncing issues...
on Sep 27, 2010 at 8:29:52 am
Hey Folks,
Recently I attempted to make add in some additional footage and end credits for a completed feature length project. All things seemed fine and were in working order. However, after a final render, I saved the project, but then discovered that 1/2 - 2/3's of the project has become out of sync. I've tried everything imaginable to fix the issue, and being not too accomplished an editor - more producer/director than editor - I'm at a loss as what to do to fix the problem? I don't want to go frame by frame, and need a solution. I was told by someone that there is a global sync in FCP 6, but how do I apply this approach?
Thank you.
Jerry Hofmann
Re: Syncing issues...
on Sep 27, 2010 at 6:03:01 pm
What are the properties of the clips, and what are your sequence settings set to be?
There isn't a "Global" Sync command...
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
DVD:http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX Cinema Displays
Strider Cangiano
on Sep 27, 2010 at 6:16:18 pm
Jerry,
To begin, thank you for taking the time to respond to my query/plight. Unfortunately, I am a neophyte - particularly in the language of... - editing. I've been fortunate enough to have worked with & have had great editors work with me on numerous projects. As such, I've been applying what seems more intuitive than anything "formal" terms of my training/skill set.
If you can clarify how best to answer your questions, I'll pursue and respond post haste.
Again, thank you.
Jerry Hofmann
on Sep 28, 2010 at 1:35:17 am
The clip properties are found by selecting one, then typing cmd+9 (apple key +9) Post what the window says.
Then select your sequence in the Browser and type cmd+zero. Post what each of these windows have to say about the clip properties and the sequence settings.
Jerry
Strider Cangiano
on Sep 28, 2010 at 1:06:32 pm
Hey Jerry,
Here's the info you requested:
Item Properties: Sequence 1
FORMAT
V1: Strategic 2010 (Ref) for web-desktop.m4v
A1: Strategic 2010 (Ref) for web-desktop.m4v
A2: Strategic 2010 (Ref) for web-desktop.m4v
Type: Clip
Creator: iTunes
Vid Rate: 29.97
Frame Size: 854 x 480
Compressor: H.264
Data Rate: 168.1 K/sex
Pixel Aspect: Square
Field Dominance: None
Alpha: None/Ignor
Composite: Normal
Aud Rate: 44.1 KHz
Aud Format: 32-bit Floating Point
Timing
Length: 01:10:34;22
In: 00:00:25;09
Out: 00:01:54;11
Duration: 00:01:29;03
TC: Source
Media Start: 00:00:00;00
Media End: 01:10:34;21
Aux TC: None
Speed: 100%
Frame Blending: On
Sequence Settings:
Frame Size: 854 x 480 (Aspect Ratio: Custom)
Pixel Aspect Ratio: Square
Editing Timebase: 29.97
Quicktime Video Settings: H.264
Audio Settings:
Rate: 48 KHz
Depth: 16-bit
Config: Channel Group
Video Processing:
Note: codecs which do not support YCbCr (also known as YUV) can only use RGB rendering,: RGB rendering may be chosen for YUV-capable codecs, but may cause intensity or color shifts in rendered material.
Timeline Options:
Starting timecode: 01:00:00;00 (drop frame is checked)
Audio Track labels: Sequential: (A1, A2, A3, A4)
Track display: show through edits is checked
Clip keyframes: all boxes are checked
Render Control:
Render & Playback all boxes checked
Render: Frame rate & resolution @ 100%
Codec: Same as Sequence Codec
Audio Output Preset:
Outputs: 2
Downmix (dB) 0
Grouping: Stereo
Jerry Hofmann
on Sep 28, 2010 at 3:51:33 pm
I know what your problem is!
FCP doesn't support h.264 nor MPEG -4 editing.
You need to transcode (re-compress) all footage like this to ProRes before you edit. Sorry to be the bearer of bad news, but it's a fact.
This recompression can be done by importing the footage to compressor and selecting ProRes as the format to transfer it to. Then you import those new files into FCP and edit normally.
Jerry
Strider Cangiano
on Sep 28, 2010 at 6:19:21 pm
Thank you for clarifying. Would changing my render set up from H.264 to Pro Res also have the same result? If not, leaving the Pro Res setting as the desired means should alleviate this from occurring in the future?
Strider Cangiano
on Sep 29, 2010 at 3:13:36 am
It turns out that the solution posed only works on 1/3 of the project, roughly the first 27 mins. However, there's an additional 44 mins that are still out of sync. For the record, I applied your solution via way of FCP by altering the settings and re-rendering the entire project. That being said, I'm now in the process or importing the entire project via way of compressor in the hope that this will fix the entire project. I'll keep you posted. Thanks again.
Jerry Hofmann
on Sep 29, 2010 at 1:36:59 pm
As far as I know, the only fix is to rebuild your project from ProRes files. Setting the render to ProRes likely won't fix you up.
Jerry
