Shot Numbers
Matt Hargrave
Shot Numbers
on Sep 27, 2010 at 7:34:14 am
I have what seems like a relatively simple problem but can't figure out a fix for it. Basically I just want to take one long clip, slice it up, and batch export it as many small clips in the same original order. I cut everything up using the "add edit" tool and then put them in a new bin and batch exported that. After having to manually re-name every clip (which is a bit frustrating since I am just numbering them sequentially) they export fine except for the very important fact that they are in a completely random order. Has anyone ever experienced this or know of a solution? Thanks for any help!
Matt
