Uncompressed Export does not match Sequence Settings
Scott Philbrook
on Sep 27, 2010 at 5:01:13 am
I'm running FCP7. I have a sequence that has 1920x1080 media as well as 1280x720, all at ProRes422(LT). I have finished a :30 second spot for my client and they have asked me to export an Uncompressed version at 1920 for them so they can run it through color and whatever else before it goes out for broadcast.
When I export the sequence Uncompressed, the resulting file is 720x486. My sequence settings are 1920x1080 in FCP.
What am I doing wrong? Can I deliver an uncompressed 1920x1080 file from this sequence? I know I can use Quicktime conversion, but my bigger question is why is this one defaulting to 720? And also if I use QT conversion to force it to 1920 am I unnecessarily crunching the file somehow?
They have told me they finish in 720 anyway, but I want to understand what's happening here.
Thanks in advance.
Rafael Amador
Re: Uncompressed Export does not match Sequence Settings
on Sep 27, 2010 at 8:51:10 am
Double check your sequence setting and make sure you are exporting with "Current setting".
Rafael
http://www.nagavideo.com
Scott Philbrook
on Sep 27, 2010 at 2:43:37 pm
Yes, I am exporting with 'current settings'.
Rafael Amador
on Sep 27, 2010 at 4:47:20 pm
As long as that is impossible, please re-import your clip to FC and read what it shows in the Browser.
Rafael
