Stripping alpha from QT file
Patrice Freymond
on Sep 25, 2010 at 6:25:25 pm
Hi everyone,
after searching these forums and the web:
is there a way to obtain the alpha layer of a qt file so as to modify it? Basically, turning a qt file (animation codec, or prores 4444) into two separate files?
thanks in advance
John Fishback
Re: Stripping alpha from QT file
on Sep 25, 2010 at 6:49:11 pm
See if this from Ken Stone's site helps.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
Patrice Freymond
on Sep 25, 2010 at 7:24:12 pm
Exactly what I was looking for.
Did not think about using Motion for this.
Thank you
patrice
John Fishback
on Sep 25, 2010 at 8:16:39 pm
I'm glad it worked out.
John
Tom Wolsky
on Sep 25, 2010 at 10:02:53 pm
Are you trying to export a matte layer from FCP? If so you can do that in FCP without going to Motion.
All the best,
Tom
Class on Demand DVDs "Complete Training for FCP7," "Basic Training for FCS" and "Final Cut Express Made Easy"
Author: "Final Cut Pro 5 Editing Essentials" and "Final Cut Express 4 Editing Workshop"
Rafael Amador
on Sep 26, 2010 at 2:42:24 am
FC don't have the export only Alpha option, but you can export a B & W matte to be used for Luma Matte in FC or interpreted as an Alpha Channel for AE, Motion, etc.
- Put a black in Layer 1 and a white in Layer 3.
- In Layer 2 set the picture with the Alpha Channel.
- Set Layer 3 as "Travel Matte Alpha".
Export in whatever codec you prefer.
Rafael
http://www.nagavideo.com
Patrice Freymond
on Sep 26, 2010 at 7:59:10 am
Well,
at least two solution to my problem.
I am lucky ;-)
Thank you all
patrice
