Can you pan audio tracks on t/l before adding content?
steve dann
on Sep 25, 2010 at 2:08:31 pm
That's it really, I kow how to pan individual clips or whole tracks and how to select stereo and mono for the t/l but is there a way to set pan on tracks before you start dropping clips in.
Ideally I'd like tr 1 left tr 2 &3 centre.
Jerry Hofmann
Re: Can you pan audio tracks on t/l before adding content?
on Sep 25, 2010 at 3:26:43 pm
No way to do this to a track before you've added the clips I'm afraid.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
DVD:http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX Cinema Displays
John Fishback
on Sep 25, 2010 at 4:49:39 pm
You can speed-up the process by setting the pan of your first clip, copy it (Cmd-C), select the following clips, and then Paste Attributes (Opt-V) select Audio > Pan.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
Nick Meyers
on Sep 27, 2010 at 12:03:01 pm
you cant assign any value or effect to individual tracks,
BUT
you can assign a specific OUTPUT to an individual track.
so if you have an i/o card with lots of audio outs you can set your timeline up so that specific tracks send to specific outputs.
you do all this in the sequence settings > audio outputs panel.
if your audio card is feeding a mixer you are all set.
QuickTime Movie exports from this timeline will have separate mono audio tracks for each separate output.
nick
