SD miniDV Pal 24fps uprez HD pro res 422 1280 X 720 @ 60p
Mike Whitehead
on Sep 25, 2010 at 8:59:20 am
Hi There, when trying to export from SD to HD as above there is a 2.5 ratio of time occurring. I.E capture 10 min of SD bring into time line, export out with above settings and only 4 mins of uprez .mov exists. 30 min of SD footage 12 mins of HD. All seems to sit around "2.5" ratio. Can anyone shed light on this?
This is to uprez archive footage for future editing
Jerry Hofmann
Re: SD miniDV Pal 24fps uprez HD pro res 422 1280 X 720 @ 60p
on Sep 25, 2010 at 1:34:50 pm
Not sure what's happening there, but up converting the footage for archiving isn't a good idea. You'll only lose quality doing it, and down the line the up conversion algorithms may be much better than they are today.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
DVD:http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX Cinema Displays
Rafael Amador
on Sep 25, 2010 at 3:15:51 pm
[Mike Whitehead] "I.E capture 10 min of SD bring into time line, export out with above settings and only 4 mins of uprez .mov exists. 30 min of SD footage 12 mins of HD. All seems to sit around "2.5" ratio"It seems that you have Conformed the p24 to p60.
I can't understand you you have done that in FC.
Apart of that I agree with Tom about archiving that stuff.
rafael
http://www.nagavideo.com
