Camcoder info for fcp
Chai Sokoloff
on Sep 22, 2010 at 9:56:38 am
I am not sure its the right place for this but:
I am trying to import/capture some materials from my new sony HDR-CX350V(avchd), but i am having hard time to find real & pro info about the files(fields,codec,sq pixels).
Its weird that sony or other brands does not publish pro info for pro peoples using Camcorders.
Thank you
Jerry Hofmann
Re: Camcoder info for fcp
on Sep 22, 2010 at 12:32:58 pm
First transfer the files from your camera to a hard drive. Leave the file structure alone and copy it all.
OPen the log and transfer window in FCP: shift+cmd+8. Then navigate to the copies on the drive, and they will load into the window. Then drag them to where it says to drag them to. FCP will import the files as ProRes files. Then edit from these files which will be located in your Browser.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
DVD:http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX Cinema Displays
Chai Sokoloff
on Sep 23, 2010 at 12:57:47 pm
Thanks, but i wish it was that easy... For me, 80% of the time fcp does not recognize the file structure after it has been moved to an ext. HDD.. It seems that fcp knows that its not the camera, and has issues with it.
I am sure i copyed all the files.
Thanks for answering...
MBP Intel i7, 4gb ram, 500gb.
Jerry Hofmann
on Sep 23, 2010 at 1:12:34 pm
The only time I've seen problems copying tapeless media from the card or drive that originally recorded it is when the copy wasn't EVERYTHING that was on said original recording media. Folders, files and their exact original file structures have to be identical with the original files. Shane's tutorial explains all this, and I'll wager it will fix you right up.
Jerry
Shane Ross
on Sep 22, 2010 at 1:30:22 pm
tutorial: Tapeless Workflow for FCP 7 Tutorial
Shane
Jerry Hofmann
on Sep 22, 2010 at 1:35:22 pm
And it's a dandy one! I forgot you just did this for the COW!
Jerry
Zane Barker
on Sep 22, 2010 at 4:00:19 pm
[Chai Sokoloff] "I am trying to import/capture some materials from my new sony HDR-CX350V"
[Chai Sokoloff] "Its weird that sony or other brands does not publish pro info for pro peoples using Camcorders."
They do on pro cameras, that camera is far from pro.
**Hindsight is always 1080p**
