Finding duplicate stills in the timeline
antonio scarpitta
on Sep 21, 2010 at 11:17:28 pm
Hello all, I am working on a feature documentary which is 1 1/2 hours with and has over 400 stills. I know that FCP has a show dups feature but it only seems to work with video clips and not stills, am I correct here?
My question is how can I tell if there are repeated stills in my timeline w/o going crazy looking for them?
I am using FCP6,
thanks for all your help,
A.
John Pale
Re: Finding duplicate stills in the timeline
on Sep 22, 2010 at 12:22:45 am
1. Create a bin.
2. select all in your timeline
3. Drag everything into the bin.
4. Sort by name. If you see multiples of the same you have dupes.
antonio scarpitta
on Sep 22, 2010 at 4:27:23 pm
Hello John, thanks so much for responding.
I will try your suggestion, it seems to be the most direct way.
Thanks again,
Antonio
Andy Mees
on Sep 22, 2010 at 6:32:19 am
Hey Antonio
The "Show Duplicate Frames" feature needs your "clips" to have Reel and Timecode associated to them (as that is how it tracks clip usage) and it will actually work perfectly happily with stills too if you provide them with appropriate tracking data. You can do that using the Modify menu > Timecode function, but take care that each one is assigned a unique Reel or unique Timecode otherwise they'll all appear to be duplicates of each other.
Best
Andy
antonio scarpitta
on Sep 22, 2010 at 4:24:59 pm
Hello Andy, thank you so much for your response.
That is what I was afraid of. It will be a good note for when I star my next documentary to do it from the start.
Thank you again.
Antonio
