XDCAM EX 720p50 slow mo
Gergo Szabo
on Sep 21, 2010 at 6:46:29 pm
Hello,
I have shot some clip with the SONY EX1R in 720p 50fps and 25fps. I would like to mix it like the 50p clips would be slower than the 25p. I have made a ProRES 720p25 timeline and Imported the 50p clip to it but It's normal speed.
Do you have any idea?
Gary
Stephan Walfridsson
Re: XDCAM EX 720p50 slow mo
on Sep 21, 2010 at 7:03:19 pm
Open your 50fps clips in Cinematools and use the Conform option to change the speed to 25fps.
/Stephan
Gergo Szabo
on Sep 21, 2010 at 7:52:40 pm
Thanks for the fast answer. At the time I have found a video tutorial on this site. Only thing I had to do the Recompress the clip to ProRES 422.
Best Regards
Gary
Rafael Amador
on Sep 22, 2010 at 1:07:39 am
[Gergo Szabo] "Thanks for the fast answer. At the time I have found a video tutorial on this site. Only thing I had to do the Recompress the clip to ProR"
Hi Gergo,
Yes, you need to transcode first, because CinemaTools can not run in GOPs stuff.
BE CAREFUL and duplicate the clips that you want to slow down. The "Conforming" has no way back.
Rafael
http://www.nagavideo.com
John Fishback
on Sep 21, 2010 at 8:30:12 pm
Here's a tutorial by Shane Ross how to use Cinema Tools to do what you want.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
Gergo Szabo
on Oct 25, 2010 at 10:25:13 am
Do you know any batch solution for this problem?
