Final cut pro don't want to open motion file
Francisco Vazquez
on Sep 21, 2010 at 3:07:20 am
What to do when Final cut pro don't want to open motion files. I have several project files with Motion clips. and the FCP crashes every time I try to open them. Can someone help?
Rafael Amador
Re: Final cut pro don't want to open motion file
on Sep 21, 2010 at 5:00:37 am
Hi Francisco,
Export the stuff directly from Motion and bring it to FC.
Cheers,
rafael
http://www.nagavideo.com
Francisco Vazquez
on Sep 21, 2010 at 10:40:51 pm
Hello Rafael: Nothing works. FCP doesn't want to open any Motion files. Not even new ones. At this point, will you recommend to uninstall and install the suite again?
Ben Holmes
on Sep 21, 2010 at 10:57:20 am
As keen as Apple are to suggest that you can drop Motion files directly onto a FCP timeline, in practice it is slow, unreliable and generally to be avoided. Render them out from Motion as ProRes 4444, the default now I think, and drop them straight onto your FCP timeline - if this is ProRes too, no rendering will be required.
Avoid all .motn files in FCP wherever possible - it's just another area where FCP needs a massive overhaul.
Edit Out Ltd
FCP Editor/Trainer/System Consultant
EVS/VT Supervisor for live broadcast
RED camera transfer/post
Independent Director/Producer
http://www.blackmagic-design.com/casestudies/detail.asp?case=therydercup
Francisco Vazquez
on Sep 21, 2010 at 10:41:48 pm
Hello Ben: Nothing works. FCP doesn't want to open any Motion files. Not even new ones. At this point, will you recommend to uninstall and install the suite again?
Rafael Amador
on Sep 22, 2010 at 1:14:39 am
No Francisco. Don't break your head and fallow Ben advice.
Export a self-contained movie frm Motion and import to FC.
The round trip FC-Motion-FC never had worked properly.
rafael
Francisco Vazquez
on Sep 22, 2010 at 8:44:21 pm
Does that mean that I have lost the FCP projects that have been working for the last four weeks?
Rafael Amador
on Sep 23, 2010 at 1:03:17 am
Why should mean that?
You take the file from Motion and you import to the FCP projects where you have been working for the last four weeks.
rafael
