Is there a way to convert quicktime files to pro res format??
Katrina Choy
on Sep 20, 2010 at 7:32:13 pm
Hi there, I have just been asked to send a film in apple pro res format, but i edited my film in premiere pro cs4. Is there a way to convert the latter to pro res format??? Or am I talking nonsense...
Shane Ross
Re: Is there a way to convert quicktime files to pro res format??
on Sep 20, 2010 at 7:41:30 pm
You need FCP 6 or 7 to encode to ProRes. They are the only software that allow for ProRes encoding.
Explain your dilemma and ask for an alternative option.
Shane
matthew bradshaw
on Sep 20, 2010 at 9:23:49 pm
No you are not talking nonsense! You need to export your finished movie and then convert it to prores. As Shane says, you will need access to FCP 6 or 7 in order to convert to prores.
Matt.
Katrina Choy
on Sep 20, 2010 at 9:41:16 pm
THanks Shane and Matt! I dont have fcp so will use yousendit instead! thanks for your advice!
Michael Sacci
on Sep 20, 2010 at 11:10:18 pm
[Katrina Choy] "I dont have fcp so will use yousendit instead!"
How does yousendit get you video into the ProRes codec?
Tucker Quenette
on Sep 20, 2010 at 11:12:06 pm
would another option be to play it to a device such as a ki pro from aja?
Michael Sacci
on Sep 21, 2010 at 12:00:28 am
While that would work, that is a pretty expensive way to do it. My thinking is that a person with FCP most likely would own a Ki Pro.
Doug Nichol
on Sep 21, 2010 at 3:50:19 am
You can also just download MPEG Streamclip and convert the QT to ProRes.
Rafael Amador
on Sep 21, 2010 at 5:04:42 am
[Doug Nichol] "You can also just download MPEG Streamclip and convert the QT to ProRes.
Doug, the only way to get Prores exporting is having FC 6 up installed in the computer.
rafael
http://www.nagavideo.com
