Smoothcam in HD
Jeffrey Stoner
Smoothcam in HD
on Sep 20, 2010 at 3:01:45 pm
I had used smoothcam with some older SD projects and it did exactly what it was supposed to do.
I have tried to use it in a current HD project and it just looks awful. Jumpy, grainy and completely unusable with regard to how much it degrades the footage. I mean, it looks like 2nd generation VHS footage! Bummer.
I'm sure I may have to provide additional info, but I'm not sure what settings would be required to help solve the problem.
Thanks in advance! :)
Jerry Hofmann
Re: Smoothcam in HD
on Sep 20, 2010 at 3:31:08 pm
Guts say, that GOP structured media will give you fits with smoothcam... so don't edit with it... If that's what you're doing, transcode the bits you need smoothcam for to ProRes and give that a try.
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog:
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX Cinema Displays
© 2018 All Rights Reserved
