Unknown render and dropped frames
Andrew Schiren
on Sep 20, 2010 at 2:00:59 pm
Hi there. I'm new to these forums and I haven't seen this problem before so forgive me if the solution is simple.
I have been editing in FCP 6 and have had no problem until now. I dropped a piece of footage into the timeline and had to render it which is unusual since I just edited the same footage in the same project the other day with no problem. Then when I went to over lay footage on a new track, I got a "General error 34". Then when I bump footage together I get dropped frames that I was not getting before. All of this is strange because I'm editing in the same project with the same capture that I did the other day. I'm not sure what the problem is. I'm not as familiar with FCP as I am with AE.
Thank you
Andrew
