Jerky playback when playing DVD
Ian MacKenzie
on Sep 17, 2010 at 1:10:26 am
HI all -
I recently exported a Final Cut Pro 7 project to DVD. All of it was shot DV NTSC 29.97. I had a guy do some color correcting, who re-exported the footage from Color, and I put it back into my Final Cut project file. It looks fine in my timeline and appears to play smooth.
Unfortunately, now when I output the DVD, the footage that was correct now looks jerky, like it's not interlaced properly or missing frames.
Not sure what to do... any help is appreciated!
Zane Barker
Re: Jerky playback when playing DVD
on Sep 17, 2010 at 1:59:43 am
Your going to have to provide info in the DVD, how it was created, compression settings etc. After all your problem is with the DVD right?
**Hindsight is always 1080p**
Ian MacKenzie
on Sep 17, 2010 at 2:03:33 am
DVD was created in DVD studio pro. I just went back to my final cut timeline and discovered the "shift field" filter was automatically added to the clips.
http://support.apple.com/kb/TA23309?viewlocale=en_US
it was set to +1
wonder if that has something to do with it?
Rafael Amador
on Sep 17, 2010 at 5:45:38 am
Hi Ian,
If you have edited NTSC DV footage in an NTSC DV sequence, you shouldn't have that Shift Field nowhere.
Not even in the clips coming from Color. Whatever the Color export format, they still should being Lower First.
rafael
http://www.nagavideo.com
Ian MacKenzie
on Sep 17, 2010 at 3:43:51 pm
Thanks for the help all! I'll try removing the shift field thing.
