1080i60 color bars offset
Marc Carbonneau
on Sep 15, 2010 at 5:42:18 pm
My 1080i60 color bars are completely off on the vector scope and my output has been refused by the broadcaster. I am using final cut pro 7 and outputting using the SDi output from a Kona LHi card. While the test pattern from the cardis perfect on the scope, the test from final cut are offset? As anyone ever seen that?
Jeremy Garchow
Re: 1080i60 color bars offset
on Sep 15, 2010 at 7:12:35 pm
More info, please.
Workflow, codec, versions, etc etc.
Marc Carbonneau
on Sep 15, 2010 at 7:22:47 pm
Apple prores 422 (not hq)
using thé 1080i60 Color bars
outputting to dvcpro hd using sdi output from kona lhi
latest firmware installed on kona
fc pro 7 latest version
the vector indicates that the Color range is offset, mostly in G
Michael Gissing
on Sep 15, 2010 at 10:51:53 pm
Do you have a video reference signal locking both the Kona and the deck? I have never had timing issues with SDI when both are properly referenced. If you don't then the deck must be setup to lock to the incoming SDI signal.
The only other possibility is that the Kona has a timing ofset in it. Open up the AJA Control Panel and under the Control tab, check that vertical and horizontal timing is set to zero.
Marc Carbonneau
on Sep 16, 2010 at 12:07:51 am
Even if I don't go trough the deck, the gamma are off directly from the SDI output. (I've tried my scope directly in the output)
My card is referenced with an external black that seems to work perfectly.
The control tab, horizontal and vertical are set to zero.
It seems to be a problem related to final cut pro since when I take the test pattern from the Kona control panel, the levels are perfectly in their little squares. Same if I choose NTSC color bars instead of 1080i60 !?
Is there a HD compatibility issue or something?
Michael Gissing
on Sep 16, 2010 at 7:15:00 am
That is weird. I have not heard of this problem and you seem to have things connected correctly. The only other thing I can think of is the output settings in FCP may not be correctly set to match the sequence settings.
Rafael Amador
on Sep 16, 2010 at 9:06:41 am
Find out first if the problem comes from FC.
I would export some bars on Prores and have a look.
How do the bars look in the FC waveform?
Or better, on the Color waveform.
rafael
http://www.nagavideo.com
