FCP playout to digitalbeta
Dena Curtis
on Sep 15, 2010 at 3:36:51 am
Hello I'm having trouble with my final cut pro 7 and playing out through blackmagic to digital beta.
It all seems to be playing out fine through final cut but then the monitoring off the digibeta has frozen. Does anyone know what could be causing this and what is the best way to troubleshoot it?
Michael Gissing
Re: FCP playout to digitalbeta
on Sep 15, 2010 at 4:53:15 am
Sounds like the Easy Setup doesn't match the sequence settings. Check your Audio/video settings to see if they are correct
Dena Curtis
on Sep 16, 2010 at 3:39:48 am
Thanks for your advice will check the settings
walter biscardi
on Sep 15, 2010 at 8:58:23 am
Sounds like you're sending the incorrect signal to the DigiBeta deck. Such as sending out an HD Signal which would result in the DigiBeta deck showing a frozen image.
As Michael suggests, check that your Easy Setup is correct, or if you are trying to downconvert an HD timeline to SD, ensure that your conversion is set up correctly on the video card.
Walter Biscardi, Jr.
Editor, Colorist, Director, Writer, Consultant, Author, Chef.
HD Post and Production
Biscardi Creative Media
"Foul Water, Fiery Serpent" featuring Sigourney Weaver coming soon.
Blog Twitter Facebook
Terry Gallagher
on Sep 15, 2010 at 10:36:58 am
Had a similar problem recently (same problem with digi and also external monitor), was solved by reinstalling the blackmagic drivers
