minor compression of movie without any qualityloss?
Per Olsson
on Sep 14, 2010 at 9:06:19 pm
Hi!
I recorded and edited a shortfilm in final cut and will deliver it to a filmfestival through their uploading system in http://www.imdb.com. The problem is that my shortfilm is at 2.26 GB but the maximum filesize to upload in imdb is 2 GB.
so I have to get rid of 0.26 GB by compressing it someway. The file format at the moment is:
Ive been shooting it with a Canon HV30 with this format:
Frame size:
1440x1080
Vid Rate
25 fps
Compressor
HDV1080i50
Pixel Aspect:
HD (1440x1080)
Audio format
16-bit integer
Audio Rate
48 Khz
how shall I do this to preserve maximum quality?
shall I use:
- compressor?
- final cut and mixing with the export settings?
- final cut and quicktime conversion?
and in case of any above - WHICH SETTINGS?
thanks a lot !!!
Perik
Michael Sacci
Re: minor compression of movie without any qualityloss?
on Sep 14, 2010 at 9:10:26 pm
There is no editing codec down from HDV. If you need to reduce size try H.264 1920x1080 at a really high bitrate.
But the real question is what do THEY want? Is it for the internet? Will they re-compress it?
Per Olsson
on Sep 14, 2010 at 9:12:02 pm
thanks for reply. they want a .mov file. thats all thay said. so I guess if I send it high quality it would do it. just if I can succed to get it under 2 GB
Per Olsson
on Sep 14, 2010 at 9:22:13 pm
shall I compress it to H.264 1920x1080 in compressor?
what is really high bitrate about?
thanks
Michael Sacci
on Sep 14, 2010 at 9:48:19 pm
Yes on the 1920x1080, the HDV 1440x is not a true size, software like FCP knows to play it back at 1920x, so when you convert it to H264 you would want to go to the correct size.
I would try 15 Mbps to start with. See how that looks to you.
Rafael Amador
on Sep 15, 2010 at 3:29:15 am
And set "Key-frames: AUTO".
rafael
http://www.nagavideo.com
