Live HDV to Final Cut/MacBookPro?
Myron Lenenski
on Sep 14, 2010 at 2:03:46 pm
I am going to test this today. We have an HDR-FX7 HDV camera. Our client has MacBookPro. He wants to record via Firewire the live feed from our Camera into his MacBook while we shoot a bunch of standup testimonials. We will record on tape.
Is this possible?
Rafael Amador
Re: Live HDV to Final Cut/MacBookPro?
on Sep 14, 2010 at 2:07:06 pm
You can try with the Record Video function in QT Pro.
I guess you can record native HDV.
rafael
http://www.nagavideo.com
Mark Petereit
on Sep 14, 2010 at 2:45:15 pm
Shouldn't be a problem. I used to do it all the time to record church sermons from our JVC GY-HD110U camera into a MBP for posting on Vimeo. I always recorded to tape at the same time just in case anything interrupted the live capture.
Myron Lenenski
on Sep 14, 2010 at 3:13:19 pm
Which codec do you prefer for this type of operation. Does the HDV ProRes codec work? Camera only does 1080i 29.97 FPS.
Mark Petereit
on Sep 14, 2010 at 4:00:11 pm
HDV and Prores are actually two different codecs. I think I just used HDV and never had any problems.
Michael Sacci
on Sep 14, 2010 at 4:03:22 pm
If your system can handle the HDV-to-ProRes on the fly conversion I think that is the best. It helps with editing speed, Like you mentioned test this before you go live. If that doesn't work you just record the HDV signal as is.
