FCP 7 Source Tab Shortcut
Jon Meredith
on Sep 9, 2010 at 8:58:00 pm
I have looked all over to find a short cut for source tabs and can't find anything.
I would like to use quick keys to attach and detach the source tabs in the timeline, rather than having to click on each tab with the mouse.
I looked through the custom keyboard layout menu and didn't see this as an option. Is it possible?
Jerry Hofmann
Re: FCP 7 Source Tab Shortcut
on Sep 10, 2010 at 2:59:22 am
There's no keyboard shortcuts that I know of if you're talking about the track controls. You can right click on the source control and select it's record track though if that helps. Don't have to drag.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
DVD:http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX Cinema Displays
Mariano Saban
on Jun 17, 2013 at 3:44:04 pm
Hi Jon,
i was asking myself the same question. Maybe it was a long time and you don't have the need no more, but i just found the shortcuts:
I hope that it helps you.
Best Regards.
Mariano.
