Ballooning file sizes
Scott Allen
on Sep 8, 2010 at 3:18:35 pm
I have a strange problem. At our film archive, we capture standard definition video from a DigiBeta deck to Final Cut 7.0.2, through a Matrox MXO2 box, as "Matrox MXO2 - Uncompressed NTSC 8-bit 48 kHz".
Up until the last few months, our resulting file sizes would be roughly 1.33 GB per minute. Now, they've suddenly jumped to being 3 - 4 GB per minute. The settings are the same. The software is the same. The hardware is the same. I can't see any difference, except for the ballooning size of the files. (And no, the video doesn't look twice as good 8^). We have had ongoing problems with dropped frames and freezing FCP windows, but these pre-date this issue, and they (usually) go away after re-booting/scrapping preferences.
Any suggestions would be greatly appreciated. Thank you.
Scott Allen
2.66 GHz Quad Core Intel Xeon
8 GB memory
Shane Ross
Re: Ballooning file sizes
on Sep 8, 2010 at 4:41:55 pm
Trash FCP preferences. Uninstall and reinstall Matrox drivers...get the latest ones.
Shane
Scott Allen
on Sep 8, 2010 at 8:41:54 pm
[Shane Ross] "Trash FCP preferences. Uninstall and reinstall Matrox drivers...get the latest ones"
Thanks. The FCP prefs have been trashed (many times), but we haven't tried uninstalling/reinstalling the Matrox drivers. We have the latest ones.
If that doesn't work, I'm thinking about re-installing Final Cut, or even the Mac OS itself.
Scott
David Roth Weiss
on Sep 8, 2010 at 5:00:26 pm
[Scott Allen] "we capture standard definition video from a DigiBeta deck to Final Cut 7.0.2, through a Matrox MXO2 box, as "Matrox MXO2 - Uncompressed NTSC 8-bit 48 kHz". "
Time to start using ProRes my friend. 8-bit uncompressed is 20th century technology...
Scott Allen
on Sep 8, 2010 at 8:37:44 pm
[David Roth Weiss] "Time to start using ProRes my friend. 8-bit uncompressed is 20th century technology..."
Well, while I'm all for using this century's technology (8^), we're pretty concerned about using either uncompressed, or losslessly compressed codecs. I read conflicting things about ProRes and compression. "Visually lossless" is great for display, distribution, etc, but for archiving, that doesn't promote total confidence.
Are any of the high-end ProRes codecs truly lossless? Also, what about either jpeg 2000 or photo-jpeg? My current boss seems pretty high on these, but each seem to have their own issues, either with compression or functionality within Final Cut.
Scott
Shane Ross
on Sep 8, 2010 at 10:20:05 pm
ProRes is 10-bit. Uncompressed 8-bit is...well...8-bit. You will have less compression artifacts with ProRes 422 than you will with uncompressed 8-bit. It is a VERY EFFICIENT compressed codec. Like Avid's DNxHD line. Perfect for ARCHIVING. Since uncompressed is so large. Unless you want to archive and be able to give that to multiple-edit systems. Then Photo JPEG would be the answer, but you can't capture directly to that format.
Do this. Capture a clip as 8-bit UC...then the same clip as ProRes 422. Look at the footage, with your eye, on the scopes. Judge for yourself how this codec holds up.
Shane
