How Do I Get European AVC Footage Into FCP?
Greg Ondera
on Sep 7, 2010 at 7:11:35 pm
I was just handed a pile of discs from Belgium to edit, and some of the footage is AVC and I can see it on Movist software as an MPEG-2 Transport Stream. I need to convert it but neither Compressor nor Episode is willing to do it. So how do I get this stuff into FCP? Here is the breakdown on the footage I see in MediaInfo:
General:
BDAV: 627 MiB, 7mn 57s
1 Video stream: AVC
1 Audio stream: AC-3
1 Text stream: PGS
Video:
10.3 Mbps, 1440*1080 (16:9), at 25.000 fps, AVC (High@L4.0) (CABAC / 2 Ref Frames)
Audio:
256 Kbs, 48.0 Khz, 2 channels, AC-3
Text:
PGS
Needless to say, I need to edit up this stuff in FCP to our standards here in the US. Thanks for any suggestions you might have!
Greg
Greg Ondera
http://www.Plexus.tv
http://www.SurgeonToday.org
John Fishback
Re: How Do I Get European AVC Footage Into FCP?
on Sep 7, 2010 at 7:58:17 pm
Have you tried MPEG Steamclip?
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
Greg Ondera
on Sep 7, 2010 at 8:53:31 pm
Just tried it and it doesn't work either. I should mention I am using FCP 6.0.6 on OS 10.5.8. It's an odd thing that I can see in Movist, but can't do anything with it.
Greg Ondera
John Fishback
on Sep 7, 2010 at 9:12:05 pm
Have you tried Perian. It's a Quicktime component so if it opens it, you'll be able to export a ProRes file.
John
Greg Ondera
on Sep 7, 2010 at 10:05:19 pm
I have Perian, but when I try to open the movie in QuickTime, it says "This is not a QuickTime file."
Greg Ondera
Martin Curtis
on Sep 8, 2010 at 12:05:15 am
If it's MTS or M2T, try something like Clip Wrap. Clip Wrap has two functions:
  • It can simply put a QuickTime wrapper around the files or
  • It can re-wrap and transcode to ProRes (and others)
HTH.
Greg Ondera
on Sep 8, 2010 at 12:14:51 am
I will try to see what the heck format it is first. Do you think it will work with 25 frame European HDV footage to take into FCP and edit it?
Greg Ondera
Greg Ondera
on Sep 8, 2010 at 12:22:42 am
Or is there a HDV driver that I could get for FCP? Or is this what ClipWrap is. Now that I think about it, this isn't the first time I have had trouble with HDV, if that is what this is.
Greg Ondera
Martin Curtis
on Sep 8, 2010 at 10:44:49 am
While the frame size suggests HDV, it seems to have been re-encoded using H.264. Is it a BluRay? I've had zero experience with BR, but the "BDAV" suggests that's what the files are.
I'll start looking for a surgeon to sort out my "mumps". Recommend any? :-)
Greg Ondera
on Sep 8, 2010 at 1:57:31 pm
Re: [While the frame size suggests HDV, it seems to have been re-encoded using H.264.]
Yes, this is my guess too, but this was not handed to me on a Blu-Ray but on a DVD+R with other stuff. Of course the whole thing came to me through several layers of people.
Thanks for your help on this!
Greg Ondera
Greg Ondera
on Sep 8, 2010 at 12:37:54 am
What a dummy I am sometimes. I just downloaded the trial and it works great! I will now buy it, so problem solved! ClipWrap, Baby! Thanks! You gotta do something about those mumps though!
Greg Ondera
Jeremy Garchow
on Sep 8, 2010 at 6:42:48 pm
[Greg Ondera] "Needless to say, I need to edit up this stuff in FCP to our standards here in the US. Thanks for any suggestions you might have!"
I would import it on a European MacPro. :)
Sorry, feeling goofy.
